1 members (Ponchogl), 130 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#86252 03/05/2005 4:01 AM
I wired up my original 6v horn in my 12v system with a 10w voltage reducer and hit the button- nothing. I then tested the wire running to the horn and found that the reducer was not doing its job and I was getting 12v which lead me to believe that I must have fried the horn so I took it off and tried it with the 6v battery in my F*^d 9N and it worked fine. So my question: Are the voltage reducers directional like a diode or is this brand new one just bad? Why will the horn honk on 6v but not do anything on 12v?
#86253 03/05/2005 3:17 PM
the horn works off of the ground rather than hot wire so i am told. maybe you have it wired backwards. i have my hooked up to 12v no problem. no reducers either, been that way at least 21 yrs. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#86254 03/05/2005 9:30 PM
Riding in the Passing Lane
You can run the 6volt horn on 12 volts but its best to wire in a relay. Some guys look for 6 volt horns cause they are louder. smile
1972 Chevy c10 Cheyenne Super
#86255 03/05/2005 10:06 PM
I must have had a bad connection because it will work on 12v but sounds odd. I also tested the voltage reducer and when it has no load it passes the full battery voltage but with a load, even a light bulb, voltage drops to .7 volts so I when down to the local electronics store and bought the same reducer I got for the gas gauge for $1.20.
#86256 03/05/2005 10:26 PM
No No! That gas gauge risister won,t last 2 seconds on a horn. You might use a ignition resistor. smile
#86257 03/05/2005 11:07 PM
Ive used the same 6 volt trumpet horns for over 15 yrs now, in different cars Ive had. Never a problem!
I use a Mopar starter relay as a horn relay, works best!
I have the loudest Saturn on the road!! grin
John Kennedy
1950 Suburban street rod
Pics in the Gallery.......
new site up!
http://home.joimail.com/~kennedyjp/
#86258 03/05/2005 11:15 PM
How many amps does a horn draw?
#86259 03/13/2005 3:58 AM
Finally found a spec for my horn and it draws 17 amps. Is there a voltage reducer that can take this kind of load? I tried the horn with 12 volt but it just doesn't sound right.
#86260 03/14/2005 10:11 PM
8
8 Offline
I would just wire it straight to the 12 volt. I did this with the original horn from the '51, and more recently with the accessory matched horns I installed. The horn is like the starter-it doesn't mind 12 volts, just don't hold the button for minutes at a time, or it might fry. Make sure the contacts inside the horn are clean. It should sound the same on 12v as 6v, only LOUDER.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#86261 03/14/2005 10:23 PM
The 6v horns give a manly sound with 12v and won't complain as long as you're not the kind of person who uses the horn as a weapon grin
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
#86262 03/15/2005 3:38 AM
I'll check the contacts and try not to honk to long. I am the kind of guy that rarly if ever honks but when I do, it's one of those longer HO... you stupid #$@&... NKs grin
#86263 04/02/2005 12:53 AM
Apprentice
Apprentice
best way to make a 6-volt original horn (50 chevy 3100) sound great is to install a 6-volt alternator. Horn is 3 times louder/clearer lights white at idle, engine starts quick when warmed up ,fuel gauge is more better accurate,the old 216 runs 30 % better.This flame thrower would run a v-8. 12 volts---nosir. 50 chevy 3100
rrf
#86264 04/02/2005 5:20 AM
I wired mine with a relay, and it sounded odd also. I took apart the horn button and found the contacts were a bit rusted, so I sanded them down a little to new metal, and now it sounds great!
1948 3600 thriftmaster
