| | | Forums66 Topics128,180 Posts1,057,149 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 71 | Hi Guys,
I finally lowered by rebuilt 235 into my 1959 truck. Word to the wise, you CANNOT install the motor and transmission into the truck at the same time, the tans is too tall to fit between the crossmember and body.
This brings me to my question, can I start/run/cam break-in the 235 with the clutch and pressure plate installed without a transmission? I would like to break-in the motor with one less thing to worry about, and starting without the transmission would isolate any clutch issues from the initial 20 minute run.
Thanks, Vince | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I just got done doing mine, all it has on it is the bellhousing and the flywheel, I don't see how adding the clutch and pressure plate would make any difference. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Just make sure the throwout bearing is removed or it could get bound up in there.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 71 | Will do, thanks guys.
Here's hoping for a successful start tonight! | | |
