0 members (),
80
Mod | | | Forums66 Topics128,062 Posts1,055,857 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 17 New Guy | | New Guy Joined: Mar 2008 Posts: 17 | My uncle left me a 55 Chevy 1/2 ton pickup. It is a field truck without an engine or transmission. I'm thinking about putting a hopped up 235 in the truck. I love the look of the inline sixes, and I don't want to have the same SBC that everyone else has at car shows. An added benefit is that I already have a 235 that I can use. The truck will be used as a cruiser, not a hauler. I would like to be able to run power steering, A/C, and possibly a TH350 transmission. Will a 235 have sufficient power to run the options that I would like to have and still keep up with traffic on an interstate, or would I be better off running a 250, 292, or 302? | | | | | Joined: May 2012 Posts: 89 Shop Shark | | Shop Shark Joined: May 2012 Posts: 89 | The 235 was actually the first engine used in the original corvette. Obviously it weighed a lot less, but I like to think it has some power.
I plan on using mine as a cruiser as well and from everything I've read, you should be fine. In the bel-airs, some guys claim to get up to 90 mph on the highway, at least on forums I've read. With a truck, I'd guess you could push 60 after all those mods.
So while you won't get the best acceleration or top speed, you should be fine for running on the highway. At least I hope so, because that's my plan! | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | A 292 would match up better to a th350. Any of the above engines would work. The 250 and 292 would likely be easier to run a compressor and power steering pump on. It is possible to run them on a 235 or 302, but it would take a little more figuring. I know there is a generator option with a power steering pump attached to the back in tandem. Those pumps tend to be pricey, and most people prefer the reliability of an alternator to the generator anyway. | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Power steering pump and A/C compressor bracketry for 235/261 engines is available from Buffalo Enterprises. Also he has a 2 groove harmonic balancer available.
regards, Leon | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I would say the biggest drawback is the pricey transmission adapter needed to run a TH350. A 230,250,292 would be much easier and cheaper.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Why not use a PowerGlide as originally used and save the cost of the adaptor. The PS/Generator setup was original to cars of that era and that would not only get you what you want but would keep it original as well. I'm not sure if PS was offered on the pickups or not. Frankly I doubt it but the parts would still work on your engine.
A Hydramatic was also used in that time frame for pickups. You don't say if your truck is a first or second series 55. The second series would make more sense perhaps.
| | | | | Joined: Mar 2008 Posts: 17 New Guy | | New Guy Joined: Mar 2008 Posts: 17 | I appreciate all of the responses. The truck is a 2nd series. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Why not use a PowerGlide as originally used and save the cost of the adaptor. The PS/Generator setup was original to cars of that era and that would not only get you what you want but would keep it original as well. I'm not sure if PS was offered on the pickups or not. Frankly I doubt it but the parts would still work on your engine.
A Hydramatic was also used in that time frame for pickups. You don't say if your truck is a first or second series 55. The second series would make more sense perhaps. The 'Glide was never used in the Task Force trucks, only the Hydramatic. Power steering was an option, using the generator mounted pump and hydraulic cylinder on the axle. It is available reproduction, but is very pricey ($700 last time I checked for just the controls, hoses, and cylinder, no pump).
Bill Burmeister | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Thanks Longbox., I always wondered about that. The poster did not say whether it was an AD or TF design however so I didn't know. Regardless it doesn't change my point that everything will work fine on the 235 w/o standing on your head and buying a bunch of expensive parts. The PS parts are available without buying new repo parts too so it doesn't require a ton of money. | | | | | Joined: Mar 2008 Posts: 17 New Guy | | New Guy Joined: Mar 2008 Posts: 17 | It's a 55 2nd series TF design. | | |
