| | | Forums66 Topics128,036 Posts1,055,454 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | Hi Folks! My 55 series II LWB half ton, model 3200, has a two piece driveshaft. I want to replace the universal joints on the rear shaft. I'm not sure that the u-joints are the same. The rear joint is held to the differential input yoke by u-bolts. The front end at the splined slip joint (yoke?) is held by clips. The front joint appears to have larger diameter caps. I'm not sure. Could take it apart and measure but thought I'd ask the experts first... Many Thanks | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Hi Sepp, I have no answer for you but if you don't have this link bookmarked it may lead to your answer. Just as a guess I wouldn't be surprised if you have to drop both ends to get at the center. 55-2 universal joint - from manual for sure the guys here will know.
| | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | Measure the diameter of the end cap, and the distance from the outside surface between end caps and check the chart here for the series type on page 5. http://www.certifiedpower.com/downloads/JOINTDRIVELINE_ID_PART1_8_05.pdf
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Or do what I do take them out and go to the flaps and they will match them up for you.Just today put new ones on my 53 GMC 3/4 ton.
Pete
