| | | Forums66 Topics128,088 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It is a replacement single-action fuel pump. They are readily available from most vendors. I think you would want a 52-57 fuel pump.
Chevs of the 40s and some other vendors sell rebuild kits.
A dual-action fuel pump was optional. It allowed the original standard vacuum wipers to work better.
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Now, while we are speaking of fuel pumps, what's the difference between this 52-57, and a pre 52 pump? Just the glass bowl? | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Any possibility the gasket is leaking? Not sure about the brand of fuel pump you have. Looks exactly like the one that was on my '54 when I bought the truck. The '29-'54 MPC defines the fuel pump as Group #3.900, Part #5592627, "(angle outlet) (AC-9798 or AC-9832)" The Factory Assembly Manual shows part number #1539832. Later model AC-9798 pumps were metal top pumps like yours. Don't know if they were originally glass bowl top like the one shown in the Factory Assembly Manual. Also don't know if AC-9832 was glass or metal top. The pump was changed to a metal top in 1955. The in and out fuel line ports on the pump are angled 20deg to the block, as are yours. The ports were first angled in 1952. My metal top pump was working fine, but I wanted a glass bowl fuel pump. So I bolted the top and bowl from a reproduction glass bowl pump onto the base of my metal top pump. Works perfectly. The glass bowl pump had the wrong in/out ports and did not work on my engine. After I screwed it onto the metal-top base, the in/out ports were angled the correct 20deg. < CLICK > for slide show of my "Frankenpump"
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Christopher, You asked your question while I was typing my reply to BruceO. ... The in and out fuel line ports on the pump are angled 20deg to the block ... The ports were first angled in 1952 ...The pump was changed to a metal top in 1955. GM sold a 20-deg fitting to allow the newer pump to be used on older trucks that had the in/out ports parallel to the block. Group #3.900 Part #3707972Don't know if there were internal changes. A local shop installed the reproduction (parallel port) pump on my '54 235. They told me that it didn't work. I don't know if it was a defective pump, defective installation, or the wrong pump. I bought the pump from the old Chevy Duty (now Classic Parts) in 1999. Didn't put it on until 2011. Chevy Duty item #82-232, "Glass Bowl Type Fuel Pump 47-54" $34.95. The in/out ports were parallel to the block. As I noted, the ports were angled 20 deg to the block after I attached the glass bowl top to the old metal-top pump. I checked the Classic Parts site. Glass bowl pump #82-232 that was listed for 47-54 in 1999 is now listed for 37-51 $64.95. Classic Parts pump #82-212 is listed for 52-57, $54.95. It has a metal top.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1952 pass started side motor mounts. The pump in and out positions were changed to clear the mount.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 56 | Thank you guys! love this forum.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I get it now. That's timely for me. Today at the swapmeet, I bought an NOS fuel pump, labeled 37-51 I think, for $10. Hussah for me!!
I find these sort of details are fascinating. | | |
