0 members (), 125 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
#861479 06/23/2012 9:10 PM
if anyone is under a Task Force 1/2T truck with a camera handy, could you take a picture of where the end of the front fender brace bolts to the cab? i have the assembly manual it it seems to suggest a hole on the firewall/plenum, but my cab does not have them (probably "repaired" away in the past). the drawing in the manual is tough to decipher. thanks
tom
Here's a shot of my Blue Chip if it helps. You can make out the cab mount lower right for reference. That's the body seam the brace bolt is mounted through, no special bracket.
GMC mounting location
Give me ambiguity
or give me something else
Did your have braces on the front fender? I have a '55 3200, and it did not have any braces on it. There are no provisions for any braces on it at all. Perhaps a running change?
Bill Burmeister
CASO - thanks, that pic does the trick because that is where i suspected that it went.
LONGBOX - my front fenders have mounting tabs on the inside of the lip to accept a brace. I swapped cabs and there are no holes where CASO shows. so i'll have to drill them.
