| | | Forums66 Topics128,277 Posts1,058,453 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | if anyone is under a Task Force 1/2T truck with a camera handy, could you take a picture of where the end of the front fender brace bolts to the cab? i have the assembly manual it it seems to suggest a hole on the firewall/plenum, but my cab does not have them (probably "repaired" away in the past). the drawing in the manual is tough to decipher. thanks
tom | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Here's a shot of my Blue Chip if it helps. You can make out the cab mount lower right for reference. That's the body seam the brace bolt is mounted through, no special bracket. GMC mounting location
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Did your have braces on the front fender? I have a '55 3200, and it did not have any braces on it. There are no provisions for any braces on it at all. Perhaps a running change?
Bill Burmeister | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | CASO - thanks, that pic does the trick because that is where i suspected that it went.
LONGBOX - my front fenders have mounting tabs on the inside of the lip to accept a brace. I swapped cabs and there are no holes where CASO shows. so i'll have to drill them. | | |
