4 members (TUTS 59, PAUL Berardi, wilbur53, 1 invisible), 112 guests, and 0 robots.
Topics128,132
Posts1,056,376
Members48,441
OK, have a stock 350 Chevy using an electric fuel pump, mounted near the tank per manufacturers recommendations. Runs great, no problems, until it is really hot, like yesterday (95.) After driving, when I stopped to get gas, had car shut off for 10 minutes or so, turned on key, and the pump made the loud hammering, indicating it was sucking air. I started the car, no problem. But the noise continued for maybe 30 seconds, quieted down, and I drove home 30 miles. Usually, it just clicks, but since it got hot, this is happening. Any thoughts, suggestions, or whatever would be appreciated!!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
Sounds like an issue with the pump, is there an tech line for the manufacturer?
Give me ambiguity
or give me something else
B Online: Content
Or a suction side leak.
BC
1960 C60 pasture art
Just a thought. If the tank is not properly vented and builds a small vacuum, then when the pump shuts off (when truck is off) the vacuum in the tank sucks the pump intake line dry. This would possibly be irratic and not occur on short trips, but only longer ones when vacuum has time to build up. Easy test is to remove the gas cap and stuff a rag and see if problem goes away. Also see if you feel a vacuum when you release the gas cap. Just a thought. I hope it's an easy fix. thumbs_up
Thanks for the ideas, will check them out this week. Any more are welcome. smile
