5 members (Phak1, Gray_Ghost, NJC, Otto Skorzeny, UtahYork), 102 guests, and 1 robot.
Topics128,057
Posts1,055,810
#860953 06/21/2012 5:45 PM
Hi guys! My panel has arrived - let the work begin! But meanwhile I have a bunch of questions...
Here are pics:
http://tinyurl.com/LarryBears55
1 - Rear sill had been whacked - are there replacements?
2 - Right rear inside - is that a clip for the jack? Where did the spare mount?
3 - Any source for a replacement lighthousing?
4 - Drivers seat looks like a replacement - pics 9 & 10 look like the original seat. I haven't decided about the seats yet is a drivers seat available out there?
5 - Scored 4 original hubcaps!
6 & 7 - Left barn door - 7 shows a release pin - looks like an add on -- yes?
Floor - from underneath is looks like a sheet of plywood. Inside - is it planks or the same plywood?
That's it for now... thanks for your help in advance!
Larry Bear
55.5 Chevy 3100 Panel
1 - rear sill is hard to repair, but the only choice unless you can find a good used one
2 - that's the jack rack, but I've never seen it there, either under the front of the driver seat or under the hood
3 - if you mean the license light, the one you have is similar to the 57-59 assembly shown here, but on a 55 it should be the earlier style, like the AD - must be cuz of replacement doors
4 - yes, that driver seat is cobbled up, the pass side is the original driver seat - used might be found, they were the same in AD years and I believe in the base sedan delivery
6 - yes, that bottom latch was added
and yes, the floor is one over-size sheet of 3/4 ply with the skid strips inset, special order if you want to replace it
Thanks for the info Bill! That's helpful.
Here's where I'm at: http://tinyurl.com/LarryBears55
Anyone out there have an extra rear sill for a 55/56 panel????
Larry Bear
thumbs_up always like seeing TF panels resurrected!
the sill is the same '55 2nd to '59, but where it bolts on to the under-structure is frequently quite rough, same as the rear lower quarters, you'll be lucky to find a parts truck it's good, but if yours isn't too much a struggle to get off a good body man could straighten it, just not something for an amateur!
