6 members (Hotrod Lincoln, Gray_Ghost, Uncles51, Hush, Hawkman, fonz8261), 195 guests, and 1 robot.
Topics128,101
Posts1,056,172
Members48,436
#86079 09/12/2004 9:05 PM
Junior Member
Junior Member
O.K. I have a 72 c/k10 pickup. I replaced a non-working gas gauge and it now reads.Thats good except it should read in the 11 to 2 o'clock position to match the gas gauge full to empty marks. Instead, it seems to want to work from the 7 to 11 o'clock position. Do I have to remove the gas gauge needle and adjust it to suit the range of motion?
#86080 09/13/2004 3:34 AM
Are you sure you have the correct Ohm sender for the tank? Kind of sounds like one of the two units "gauge or sender" are not compatible.
Joe
#86081 09/13/2004 12:23 PM
Junior Member
Junior Member
I just bought the truck a couple of months ago and I don't know if the tank sender has been changed. I bought the gauge from Chevy Duty and ordered it for the 72. It only has one wire going to it and I assume it goes to ground through the mounts on the tank.
#86082 09/13/2004 4:30 PM
The range of movement sounds good. Needle may have been bent during shipping or installation. I would pull it out again and have a look. On the older gauges (like in my 54) there is a triangular piece at the base of the needle - this can be adjusted relative to the needle to get the guage reading correctly if your needle isn't bent.
Gord
1954 1/2 ton 235 4 speed
