4 members (Sjm, TexasJim50, Chris_Welch, 1 invisible), 103 guests, and 4 robots.
Topics128,267
Posts1,058,386
Members48,485
#860760 06/20/2012 11:18 PM
So my 58 fleetside has an older 248 instaed of the 270 it's supposed to have. The quote to rebulid the 248 is $3000. If i could find a good running 235, is it much of a challenge to put it in place of the old GMC 248?
I'd be looking for a good running 270 myself.
yes, I would stay GMC, I would go for a 302 myself, I don't think I have ever heard of anyone going that way. (GMC to 235)
It must not be too hard of a conversion because I have seen a ton of gmc trucks for sale with the chevy 235 powering them. I won't buy a chevy powered gmc.
yes I don't suppose it would be all that hard to do, usually the problem I have heard of is the GMC is longer and you have that to deal with when switching from a chevy to a GMC. But I wouldn't switch to chevy either. As a matter of fact I'd like to put a 302 in my truck. As far as the price to rebuild, $3000 is quite reasonable. That is about what you will pay for any of these engines, 235's included. Not including the cost to convert, you would be much better off sticking with a GMC product, at least it just bolts in.
whats wrong with the 248? if the 248 is still running then drive it while shop a bigger motor. what is your goal here?
ODSS Lawman
ODSS Lawman
I agree with the others that it would be best to find a good GMC motor like a 270 or 302. But as Mike mentioned, I'd just drive the 248 for a while until you find your match.
However, if you are determined to install a 235, there is how 49geezer installed a 261 into a GMC 1/2 ton
Plate
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
