5 members (greenie-reddy, frogfarmer, Gray_Ghost, 2 invisible), 315 guests, and 5 robots.
Topics128,156
Posts1,057,018
Members48,460
Will the Jim carter set up
Side Motor Mount for Installing Small Block Chevrolet V8 1936-1955 Item Number: HP121
work in my 1949 suburban or do i need another kit to install my 292
Stovebolt CHEVROLET
1949 Chevrolet Suburban
Non stovebolt CHEVROLET
1958 Impala Convertible
1963 Impala Convertible
MY 1949 SUBURBAN
Stovebolt CHEVROLET
MY 1949 SUBURBAN
The 292 motor mounts are staggered. The passenger side is closer to the radiator the the drivers side. All other Chev motors are equally spaced. There maybe an adapter(?).
Larry
I don't own a vehicle that isn't old enough to drink.
www.stoveboltengineco.com used to sell a more adaptable mount, but he suggest contacting Chassis Engineering now. But, I bet there are other suppliers.
Drew
That's my issue I can't find it on their website or anyone else who list them and since they take the V-8 mounts just staggered I was hoping the Jim Carters kit would work I would just need to mount on the frame in correct spots
Stovebolt CHEVROLET
MY 1949 SUBURBAN
Ok the place is chassis engineering INC theres also and chassis engineering which is what i had originally found and couldn't see anything close to what i needed but as you can see in the pic they are the same thing as Jim Carters and it says nothing about 292 just V-8?? Chassis Engineering INC V-8 mounts
Stovebolt CHEVROLET
MY 1949 SUBURBAN
If I get a chance later today, I'll post a pic link to the set I have that originally came from Stovebolt Engine Co. That way it'll give you an idea what to look for or how to adapt a v8 set to a later L6. You might even know someone who can make a set of brackets for you. Pretty basic really.
Drew
Thanks thats wold be cool on a side note i just got off the phone with Jim and chassis eginering INC and he said they do NOT sell a kit for the 292 he said they sell a universal kit for the 250 that he has heard can be made to work for the 292 but he didnt know for 100%
Stovebolt CHEVROLET
MY 1949 SUBURBAN
Okay, here's the pic links. Chassis Eng.Inc. part number for the cushions only is SS-0011 described as "For All C.E. Engine Kits and Replaces Stock Flathead Ford Engine Mounts". The bracket number is CP-1160 and are described as "Engine Swap Kit- S.B. Chevrolet for 1940-54 Chevrolet 1/2 ton Pick Up". and yes, the 250 kit would be the same.
[IMG]http://pic100.picturetrail.com/VOL1061/3611363/23917335/403115553.jpg[/IMG]
[IMG]http://pic100.picturetrail.com/VOL1061/3611363/23917335/403115554.jpg[/IMG]
[IMG]http://pic100.picturetrail.com/VOL1061/3611363/23917335/403115557.jpg[/IMG]
Also, keep in mind that the frame narrows as you measure forward, so there is a left and right side for welding in the support channels. Hope this helps. The mounted pic is the driver side. Notice the difference from the passenger side in the other pic. It's offset.
Drew
Those mounts are not that complicated. Anyone who can measure accurately and cut/weld steel should be able to fabricate a decent-looking set of mounts. Start with the engine bolted up to the bellhousing, mounted to its crossmember, and level it in relation to the frame. Then take some accurate measurements and make a set of brackets to hold a set of "hockey puck" motor mounts. Problem solved!
I just scored a new in box langdon's kit local thanks for all the info
Stovebolt CHEVROLET
MY 1949 SUBURBAN
