1 members (1 invisible), 78 guests, and 2 robots.
Topics128,034
Posts1,055,546
Members48,425
#860380 06/19/2012 3:21 PM
For stovebolt motors (261) does the distributor vacuum advance need to be disabled to check points dwell angle and dwell variation?
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
sleeve #860385 06/19/2012 3:31 PM
Not necessarily, but it won't hurt to do so. Most dwell problems are caused by worn distributor cam lobes and/or bad shaft bushings, but the dwell does not change much like it does on a Ford distributor. On Fords, the single point pivot system at the breaker plate results in a slight dwell change as the vacuum advance moves. Not so on GM distributors.
Thanks Jerry,
This is my first time setting the point gap using a dwell meter. Up until now I have always set them with a feeler gage and called it good enough. I had initially done that with this motor and today when I checked it with the meter I found the gap to be too wide and the dwell to be about 10 degrees off so it was fun for me to get it spot on with the meter. I should have got a tach and dwell meter long ago!
-Mike-
