8 members (Hotrod Lincoln, Gdads51, Bill Hanlon, JoeDude, frogfarmer, tclederman, gswbbc, dt235sd),
85
Mod | | | Forums66 Topics128,038 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | For stovebolt motors (261) does the distributor vacuum advance need to be disabled to check points dwell angle and dwell variation?
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Not necessarily, but it won't hurt to do so. Most dwell problems are caused by worn distributor cam lobes and/or bad shaft bushings, but the dwell does not change much like it does on a Ford distributor. On Fords, the single point pivot system at the breaker plate results in a slight dwell change as the vacuum advance moves. Not so on GM distributors. Jerry
| | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | Thanks Jerry,
This is my first time setting the point gap using a dwell meter. Up until now I have always set them with a feeler gage and called it good enough. I had initially done that with this motor and today when I checked it with the meter I found the gap to be too wide and the dwell to be about 10 degrees off so it was fun for me to get it spot on with the meter. I should have got a tach and dwell meter long ago!
-Mike-
