| | | Forums66 Topics128,156 Posts1,057,021 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | Will the Jim carter set up Side Motor Mount for Installing Small Block Chevrolet V8 1936-1955 Item Number: HP121
work in my 1949 suburban or do i need another kit to install my 292 | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 |
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The 292 motor mounts are staggered. The passenger side is closer to the radiator the the drivers side. All other Chev motors are equally spaced. There maybe an adapter(?).
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | www.stoveboltengineco.com used to sell a more adaptable mount, but he suggest contacting Chassis Engineering now. But, I bet there are other suppliers.
Drew
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | That's my issue I can't find it on their website or anyone else who list them and since they take the V-8 mounts just staggered I was hoping the Jim Carters kit would work I would just need to mount on the frame in correct spots | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | Ok the place is chassis engineering INC theres also and chassis engineering which is what i had originally found and couldn't see anything close to what i needed but as you can see in the pic they are the same thing as Jim Carters and it says nothing about 292 just V-8?? Chassis Engineering INC V-8 mounts
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | If I get a chance later today, I'll post a pic link to the set I have that originally came from Stovebolt Engine Co. That way it'll give you an idea what to look for or how to adapt a v8 set to a later L6. You might even know someone who can make a set of brackets for you. Pretty basic really.
Drew
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | If I get a chance later today, I'll post a pic link to the set I have that originally came from Stovebolt Engine Co. That way it'll give you an idea what to look for or how to adapt a v8 set to a later L6. You might even know someone who can make a set of brackets for you. Pretty basic really. Thanks thats wold be cool on a side note i just got off the phone with Jim and chassis eginering INC and he said they do NOT sell a kit for the 292 he said they sell a universal kit for the 250 that he has heard can be made to work for the 292 but he didnt know for 100% | | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | Those mounts are not that complicated. Anyone who can measure accurately and cut/weld steel should be able to fabricate a decent-looking set of mounts. Start with the engine bolted up to the bellhousing, mounted to its crossmember, and level it in relation to the frame. Then take some accurate measurements and make a set of brackets to hold a set of "hockey puck" motor mounts. Problem solved! Jerry
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | I just scored a new in box langdon's kit local thanks for all the info | | |
