7 members (UtahYork, MickeyP, Gdads51, Cletus1950, TexasJim50, Hotrod Lincoln, baldeagle),
105
Mod | | | Forums66 Topics128,179 Posts1,057,068 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 89 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 89 | We have a 1954 1/2 ton.Where the torque tube goes into the rear end there is a very bad leak.It appears that someone tried to solder it to stop the leak which did not work.Is there anything you folks could recommend that i could try to stop this leak?
thank you jon | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Are you talking about where the tube goes into the cast part?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2011 Posts: 89 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 89 | yes, that spot plus oil leaking out of bottom rivets. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If it is leaking there the tube has started working loose in the housing,I have seen this before. In that case I would recommend welding all the way around the spot where the tube enters the housing.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2011 Posts: 89 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 89 | Its the bottom rivets in the housing that are leaking.Thank you pre68dave,what do you think we should do about the rivets leaking?
thanks jon | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | With it welded you can then use silicone, JB weld or your choice of sealer on the rivets.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2012 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 64 | In most of the 3 speed trans there is a gasket, felt seal and a compression seal. At the point where the tube enters the trans is a rubber gasket this can be changed (compression)There is also a felt type gasket at the ball where it flexes. It will not stop leaking until it properly sealed. If welded or epoxy is applied it will eventually fail and leak. This is a flex joint and must be repaired properly for longevity and dependability. It will leak again shortly if not done correctly. Even with new seals these will have a drip once in a while but nothing that's not normal..
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | In most of the 3 speed trans there is a gasket, felt seal and a compression seal. At the point where the tube enters the trans is a rubber gasket this can be changed (compression)There is also a felt type gasket at the ball where it flexes. It will not stop leaking until it properly sealed. If welded or epoxy is applied it will eventually fail and leak. This is a flex joint and must be repaired properly for longevity and dependability. It will leak again shortly if not done correctly. Even with new seals these will have a drip once in a while but nothing that's not normal.. his leak is at the other end | | |
