Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Hotrod Lincoln), 195 guests, and 2 robots.
Topics128,290
Posts1,058,566
Members48,492
#859956 06/18/2012 1:05 AM
We have a 1954 1/2 ton.Where the torque tube goes into the rear end there is a very bad leak.It appears that someone tried to solder it to stop the leak which did not work.Is there anything you folks could recommend that i could try to stop this leak?
thank you jon
Are you talking about where the tube goes into the cast part?
My Blog
yes, that spot plus oil leaking out of bottom rivets.
If it is leaking there the tube has started working loose in the housing,I have seen this before.
In that case I would recommend welding all the way around the spot where the tube enters the housing.
My Blog
Its the bottom rivets in the housing that are leaking.Thank you pre68dave,what do you think we should do about the rivets leaking?
thanks jon
With it welded you can then use silicone, JB weld or your choice of sealer on the rivets.
My Blog
Y
Y Offline
In most of the 3 speed trans there is a gasket, felt seal and a compression seal. At the point where the tube enters the trans is a rubber gasket this can be changed (compression)There is also a felt type gasket at the ball where it flexes. It will not stop leaking until it properly sealed. If welded or epoxy is applied it will eventually fail and leak. This is a flex joint and must be repaired properly for longevity and dependability. It will leak again shortly if not done correctly. Even with new seals these will have a drip once in a while but nothing that's not normal..
his leak is at the other end
