| | | Forums66 Topics128,259 Posts1,058,292 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I have a 1957 Chevy truck, long-bed. I am about ready to assemble the bed. It has been apart so long, I forgot how the mounting brackets for the bed side steps (gravel shields) bolt in. It looks like they bolt to the front sill (closest to cab), back side (to the rear) of the sill. The sill has two holes on each end, on one side. I think the sill needs to be positioned so the hole side faces the back of the truck. The sills are from Mar-K. Can anyone verify this,thanks. don | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | If someone with a Task Force truck could just look under the gravel shield and see how it mounts on the cross-sill, that would be much appreciated. Thanks, don
| | | | | Joined: Jan 2008 Posts: 176 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 176 | Hi Donsz,
I'll answer you from the perspective of my 55 second series. Hope it is the same as yours.
The bracket mounts to the bed cross sill just as you have said. The flat side of the bracket on my truck is forward with the channeled side toward the rear. This gives you information to distinguish right from left bracket. The holes on the cross sill are on the front with bolts going from the front through the cross sill then through the bracket and into captive nuts welded on the rear of the brackets.
If anything is not clear just ask. I will keep an eye out for you. | | |
