2 members (ShopRag, GradyB), 116 guests, and 1 robot.
Topics128,035
Posts1,055,564
#859867 06/17/2012 4:19 PM
Riding in the Passing Lane
The bell houseing for the SM465 uses a larger center hole then the earlier models. Do the 3 speed trans from the same era use the large hole also? I wound up with 2 of them from a sale & didn't realize they were the larger hole.
George
1972 Chevy c10 Cheyenne Super
not sure it's age related, the truck 3 speeds need a larger center hole than cars, I have both car and truck Saginaw [68+] 3 speeds and the car ones have a smaller front bearing retainer
Flxible #859871 06/17/2012 4:49 PM
I just helped a local bolter install a Saginaw 3-speed in a 1960 model 1/2 ton, and I had to machine the bearing retainer to fit his bellhousing. At least some of the full-synchro 3 speeds had the big bearing retainer diameter to fit the bigger bellhousing hole.
