| | | Forums66 Topics128,034 Posts1,055,533 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The bell houseing for the SM465 uses a larger center hole then the earlier models. Do the 3 speed trans from the same era use the large hole also? I wound up with 2 of them from a sale & didn't realize they were the larger hole. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not sure it's age related, the truck 3 speeds need a larger center hole than cars, I have both car and truck Saginaw [68+] 3 speeds and the car ones have a smaller front bearing retainer
Bill | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | I just helped a local bolter install a Saginaw 3-speed in a 1960 model 1/2 ton, and I had to machine the bearing retainer to fit his bellhousing. At least some of the full-synchro 3 speeds had the big bearing retainer diameter to fit the bigger bellhousing hole. Jerry
