1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 843 'Bolter | | 'Bolter Joined: Jan 2012 Posts: 843 | Hi all i have 57 3200 with 265 v8 and 3 speed box the cluch is on way out in catologues shows 3 different size clutches 9 10 or 11 inch any way i could work out which one without pulling out box have to get one freighted to australia so trying to speed up change over
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Take the dust cover off from the bottom of the bell housing than get a light and a ruler and you should be able to see what you have.You'll have to measure across the clutch.
Pete | | |
