0 members (),
47
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 10 New Guy | | New Guy Joined: Jan 2012 Posts: 10 | I have a '63 half ton pick up, 3 speed on column with an inline 6 engine. Am in the process of taking apart repairing etc. the engine will run but stops periodically, like being gas starved.....I clean fuel line and it runs fine for a while....am going to take tank out and clean....my question is should the gas run out of the tank if the line is removed......mine does not......also compressed air blown into tank does not help.....any help is appreciated.....Pat | | | | | Joined: Jun 2012 Posts: 9 New Guy | | New Guy Joined: Jun 2012 Posts: 9 | Pat, I went through the same thing with mine. If the truck has sat for any length of time the tank is most likely rusted from condensation. The best fix is to replace the tank or you will fight the issue from now on. I purchased and installed a new tank, new fuel lines and reworked the original carb. My tank cost 175 dollars....it was well worth it. Red 63' C20 Stake Bed http://s1164.photobucket.com/albums/q578/raptorsrule/ | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | A tank restoration kit from Eastwood or POR15 is an option if you have the time and don't mind working with chemicals like muriatic acid. I did a tank on my FORD and everything cost me about $70. Fairly easy to do but you have to be careful with the acid. | | | | | Joined: Jan 2012 Posts: 10 New Guy | | New Guy Joined: Jan 2012 Posts: 10 | thanks for the replys....I pulled the sending unit from the top of the tank and the line attached had a metal filter that was all corroded and plugged.....after cleaning and replacing the engine runs fine.....am in process of cleaning the engine compartment next.....this really keeps my interest going......Pat | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I pulled the sending unit from the top of the tank and the line attached had a metal filter that was all corroded and plugged..... If the stuff plugging the metal filter was rust, then there is probably more rust in the tank, and I think it won't be long until you are facing the same problem again.
