6 members (Otto Skorzeny, ShopRag, Gdads51, 55shaker, 78buckshot, Woogeroo), 147 guests, and 3 robots.
Topics128,268
Posts1,058,382
Members48,485
#859278 06/15/2012 8:49 AM
Ok the 53 Gmc project is about home. It has a 270 installed. The current owner says it might need a new coil and points/condenser. The question I have is with the jimmys being positive ground how is the coil and the above stuff wired? I am prob. making this too hard but that's me some days. Also it may have air over hydraulic brakes I know nothing of these. I can imagine it is like semi brakes of today am I right? Thanks Jay
Jdude
thet904 #859287 06/15/2012 11:11 AM
Today's Semi brakes are straight air brakes. Yours is most likely Hydraulic with Hydro-vac booster or Hydraulic with and Air Pack.
Is there an air compressor mounted on the engine just in front of the carb???
As for the coil connections, regardless of the battery ground being Negative or Positive, the hot lead from the ignition switch goes to the plus sign on the coil and the negative sign goes to the distributor.
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
GMCPic #860329 06/19/2012 8:28 AM
Thanks I haven't got the thing dragged home just yet between dad passing and making room for it. I thought the coil would be the same but after working on newer stuff for 26 years I was wondering. Its prob a air pack I think that's what the guy said. Thanks Jay
Jdude
thet904 #860378 06/19/2012 3:10 PM
3B Offline
Hy Guys, I'm afraid I have to make a correction to what GMCPic has said about coil primary wiring. Negative ground vehicles are wired ignition to coil positive, and coil negative to the distributor (and ultimatly ground). Positive ground vehicles are wired ignition to coil negative, and coil positive to the distributor, hope that clarifies.
3B #861739 06/25/2012 2:19 AM
hmm clear as mud but i just got off work
Jdude
thet904 #861766 06/25/2012 3:39 AM
I think the point is that coils are polarized. on a negative ground system the terminal marked + goes to the ignition and the negative side goes to the distributor ( where it is grounded through the points )
on a positive ground system the terminal marked + goes to the distributor where it is "grounded" (to positive)thought the points... and the other side (marked -) will go to the ignition.
Homeland defense begins at home.
