0 members (),
64
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 36 | I've read about the wiring and mounting of alternators, but haven't seen what type/size/amperage/years found to obtain. Is there a favorite one that is used? My son works at a auto junk yard and needs to know what one to get for me. Thanks | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | The one that's used most often is the General Motors 10-SI series. It has an internal voltage regulator and was standard equipment om practically all GM vehicles from the late 1970's to the early 1990's. The smaller-housing alternators from the 90's forward aren't quite as reliable, IMHO. The 10-SI has amperage capacities from 65 amps to 90+, depending on the year and application.
Unless you're running some mega-blaster sound system or a set of hydraulic pumps for a bouncy lowrider, any of them should provide plenty of current to keep the accessories running and the battery charged. Jerry
| | | | | Joined: Oct 2011 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 36 | | | | | | Joined: Feb 2012 Posts: 43 New Guy | | New Guy Joined: Feb 2012 Posts: 43 | Jerry, are the alt marked in any way to know they are 10-SI or the amps? Thanks! Didn't mean to cut in. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Google delco 10si. More info than you can use. As Jerry said, it's a common swap. | | |
