Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (Wayne67vert, 78buckshot, 1 invisible), 78 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
I've read about the wiring and mounting of alternators, but haven't seen what type/size/amperage/years found to obtain. Is there a favorite one that is used?
My son works at a auto junk yard and needs to know what one to get for me.
The one that's used most often is the General Motors 10-SI series. It has an internal voltage regulator and was standard equipment om practically all GM vehicles from the late 1970's to the early 1990's. The smaller-housing alternators from the 90's forward aren't quite as reliable, IMHO. The 10-SI has amperage capacities from 65 amps to 90+, depending on the year and application.
Unless you're running some mega-blaster sound system or a set of hydraulic pumps for a bouncy lowrider, any of them should provide plenty of current to keep the accessories running and the battery charged.
Thanks Hotrod!
Jerry, are the alt marked in any way to know they are 10-SI or the amps? Thanks! Didn't mean to cut in.
Google delco 10si. More info than you can use. As Jerry said, it's a common swap.
