| | | Forums66 Topics128,018 Posts1,055,339 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85887 05/08/2003 5:55 AM | Joined: Nov 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 46 | Searched the archive and came across many posts on this topic.
I need to remove the headlight switch on my '56 3600. The spring loaded button is on the same side as all the connections, and is actually right in the middle of 'em. I pushed the button and pulled the plunger out but it didn't come out. Do I need to "apply more force"? or is there another trick I'm missing.
The side opposite the connections is bare.
Thanks in Advance. | | |
#85888 05/08/2003 1:34 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | The button is on the side toward the drivers door. My original has connections on all sides. May have to jiggle the knob back and forth while depressing the button but it should come out. | | |
#85889 05/08/2003 2:01 PM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | "...spring loaded button is on the same side as all the connections..." not - the button is a little mushroom top pin-like thing that's on the top of the switch w/ a tiny spring around it, while the wires are on bottom where ya can see'em if ya poke yer head under there - about center of switch body, and hurts the fingertip to push it hard - knob rod has a flat on one side that may have to line up, so try turning, and push pin w/ knob in off position, then yank knob out - sometimes a bit of corrosion or something - if yours is different it's non-original - no advice available here!!
Bill | | |
#85890 05/28/2003 11:46 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | You have to pull the switch knob out to the headlight position ... THEN push the spring-loaded button ... and then pull the knob the rest of the way out.
I went nuts with mine until I made a phone call. That knob will NOT come out until you go by the above procedure.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#85891 05/28/2003 6:06 PM | Joined: Nov 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 46 | Alan...you are right. I had to pull it out part way and then push the mushroomed shaped button located between all the connections .
Thanks for all the replies!! | | |
