1 members (Thomaslb), 138 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#85877 12/25/2004 11:55 PM
Anonymous
Unregistered
Anonymous
Unregistered
Can anyone help me out? I'm trying to get the headlight switch out of my '52 chev panel.
So far, all I've suceeded in removing is the shaft/knob assy. I can't seem to be able to figure out how to remove the switch from the dash.
#85878 12/26/2004 1:03 AM
spray it real good with w d wait a few days take a needle nose and poke it in the slots and unscrew it its a treaded fiting took me a week to get mine out you can also use a small screw diver and gently tap on it keep lubing it it will come loose
#85879 12/26/2004 11:14 AM
Anonymous
Unregistered
Anonymous
Unregistered
Will try that.....Thank-You
#85880 01/03/2005 9:50 PM
I've always used a really big flat screwdriver that fits across both sides of the slot. I've never had trouble getting one out.
1954 GMC De Luxe COE
#85881 01/04/2005 6:02 AM
You might have overlooked the obvious. Make
sure you unscrew the nut that holds it to the
dash. Cecil........
#85882 01/04/2005 12:14 PM
Junior Member
Junior Member
I'm the guy "formerly" known as Lindylou.
Thanks for all the help w/ my switch. I finally got it out!
It tested fine, except for the reostat spring that controls the dash lights. That's broken. Gotta figure a way to repair it.
I'm trying to restore to near original.
#85883 01/04/2005 8:17 PM
I wouldn't try to fix it, a good used original shouldn't be too expensive. Most of the vendors carry used parts, so you might want to try them - especially Jim Carter's, they have lots of used stuff. You might also try putting an ad in the swap meet on here, I'm sure there are plenty of people on here with good spare switches to sell.
On a side note, I wouldn't try to fix broken parts, but I do like to take them apart, polish the contacts, and add some grease designed to protect electrical connections. There are a few on my shelf that still need this treatement.
