3 members (David Bush, mk72, Bill Hanlon), 130 guests, and 4 robots.
Topics128,053
Posts1,055,777
Is there any difference between a 6V starter and a 12V one? My truck has been converted to 12V and the starter looks like it might be original. None of the 12V conversion things I've read mention anything about changing the starter out. Are the original 6V'ers OK to use with 12V?
53 Dumpy
1951 Chevy 3100 "Ernestine"
1970 Chevrolet C10 "Ol' Blue"
1940 JD "long-hood" B
1959 Jeep FC-170
1960 IH B275
2013 Chevy Silverado
2023 GMC Denali 2500HD
Junior Member
Junior Member
From what I have read & heard it will (starter)love 12 volts. Crank a lot better too. I have done it to a tractor with no problem.
I've always been a little concerned that my starter might be taking on just a little too much juice since I switched over to 12v, but for now it is having way too much fun cranking right over. Besides I have another starter up in the attic......
Craig
yep - no prob running 6V starter on 12V - cranks great, ya just don't wanna try driving the last 3 blocks to the gas station on it! grin
Quote
According to the previous owner, due to the carb being off the truck for rebuild, he moved the truck around the yard using the starter. At least he did as long as it lasted. Explains why I am working on it now. I'm gonna try just replacing the brushes and bushings and putting it back together. Also gonna try to look up how to check the field coils and armature for shorts.
Is there any particular damage I should be looking for due to his using the starter as an auxilary engine?
53 Dumpy
1959 Jeep FC-170
1960 IH B275
LOL! wouldn't ya know! if the brushes aren't pretty bad lookin, or more likely the armature where the brushes contact, it prolly does have a fried winding - maybe ya got an auto electric place around that can check it out properly . . .
I think that most of use have been guilty of using the starter to move a vehicle at least once! You can check the continuity of the field and armature with an ohm meter, but the only way to really check the armature is with a growler. Shop manual shows how it's all done.
Fred
52 3600
69 C-10
I am using a 6v 216 starter on my 12V 261 with 11" clutch flywheel. I had the flywheel custom ground to fit the 6V ring gear and it's all footstomp. I kept the 4/0 cables I had with the six volt starter and it spins so fast the engine is up to idle speed before it even catches. I have run it that way for a few months with no problems. As long as you don't crank it for long enough to get the windings really hot you will be fine.
Paint & Body Shop moderator
It would appear that what the previous ownser burnt out moving the truck with the starter was the battery. Got the starter apare and the brushes didn't look too bad. Did all the tests I could (without a growler), painted it, and reassembled. While I was waiting for the paint to dry, I pulled the battery to charge and It was dead as a doornail. I tested the starter with my jumper cables on my other truck and it works fine. Looks like I didn't need to do any starter work at all. Sure is purty with it's new coat of paint though!
53 Dumpy
1959 Jeep FC-170
1960 IH B275
I just found out (thanks to 53 4 me) that mine is a 12 volt system using a 6 volt starter. I have been having the occasional problem with the solenoid fusing together if I crank too long. ...No stomper. I think this is the problem tho. I guess you can't lay on the same combination of horn too long either! - Scott
55 1st Chev.
