| | | Forums66 Topics128,197 Posts1,057,263 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 84 | I just switched the tail lights on my '51 half ton. The guy I bought it from had round, plastic trailer lights on it. I am looking for ideas for the wiring from the light to the frame. I bought the stainless conduit from Classic Parts but I think it is a generic part and it doesn't really work. Any suggestions on a visually pleasing way to run the wiring? Thanks.
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Lode51 - Your new "correct" '51 tail lights will look great on your truck. The old trailer lights were mounted on shop-made brackets, so you need new mounting brackets, too. I believe that the wires from the '51 tail lights to the clip on the frame ran through black cloth wire loom. Other forum members can tell you how the loom was attached to the light socket boot. A lot of people use chrome plated or stainless fancy loom to cover the tail light wires. I prefer the original look, but that's just me. The right tail light installation shown in the '51 Accessories Installation Manual is actually a separate turn signal lamp. A separate turn signal lamp is also used on the left side. So, you will probably do better following the '47-'54 Factory Assembly Manual to install the left light. And follow the '54 Accessories Installation Manual to install the right light and to route the wires for left and right lights. Note the location of wiring clips on the frame and on the mounting brackets. > '51 tail light - glass lens, chrome bezel, black housing> Black wire loom - cloth - various diameters> Left tail light and bracket, '47-'54 Factory Assembly Manual> Right tail light and bracket '54 Accessories Installation Manual> Right tail light and bracket; Left & Right wire routing '54 Accessories Installation Manual> Figure #197 - 1951 Accessories Installation Manual with separate turn signal lamp- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | |
