| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85839 06/23/2003 2:23 PM | Joined: Aug 2001 Posts: 35 Member | | Member Joined: Aug 2001 Posts: 35 | Is my '59 supposed to have dash lights? It seems that the gages (at least the speedometer) should have backlighting... Am I wrong? Where would I begin to look to solve this problem (assuming it should have lights)? | | |
#85840 06/23/2003 2:39 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Try looking under the dash. There should be dash light bulb housings that pop into holes in the gauge housings. Perhaps they have fallen out of the housings.
If they are in place, check to make sure the bulbs work. If all that checks out, follow the wire to the head light switch and make sure it is connected to the rheostat..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#85841 06/24/2003 12:50 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Pull the headlight switch and look at the reostat. If it looks good, slap a meter across it. The one in my '59 was in pieces. A new switch did the trick. | | |
