3 members (Hotrod Lincoln, 2-Ton, 1 invisible),
63
Mod | | | Forums66 Topics128,021 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | My foot operated starter engages sometimes and most oftenly not. It engages almost, then rattles and spinns freely, and I have to test several times before it suddenly engages and turns the engine. It sounds terrible, what is the cause of this, bad battery ? The starter block that the arm presses to is new, but it was the same before. I have seen starter parts at Jim Carters, but it's for a starter up to early -55. I have a -59 with a 261. Anyone with a good link for parts ? /Ulf My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy lastchancetowing, it might be that you have a starter drive that is worn out, and needs to be replaced, hope that helps. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | And where can I find a starter drive for a foot operated started for a -59 261 ?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Is it the same starter on the 235 as on a 261 ?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | GM parts book calls for 1932188 to fit all 6 cylinder,
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy lastchancetowing, all the six cylinder twelve volt starters used the same starter drive. My 2004 Jim Carter catalog lists their p/n ME910 $14.70 in 2004, hope that helps.
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Thanks guys... Ordering today.
