OK, so I started to feel alot of vertical play in my brake pedal and when I wen to investigate I found that the brake arm that connectect to the pedal had broken off where the bolt goes in. The PO apperently added a washer then used bailing wire to cinch down the connector. Holy crap. Question, where can I find a replacement arm? I see alot of pedals around, but not the arm. Thanks!
