4 members (JW51, dt235sd, Otto Skorzeny, 1 invisible), 103 guests, and 1 robot.
Topics128,062
Posts1,055,854
Members48,428
#858147 06/11/2012 2:21 PM
OK, so I started to feel alot of vertical play in my brake pedal and when I wen to investigate I found that the brake arm that connectect to the pedal had broken off where the bolt goes in. The PO apperently added a washer then used bailing wire to cinch down the connector. Holy crap. Question, where can I find a replacement arm? I see alot of pedals around, but not the arm. Thanks!
New_Ton #858187 06/11/2012 5:33 PM
New_Ton, Start by placing an add in the Truck Parts Wanted...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
