| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85811 07/08/2003 1:25 AM | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | I rewired my '51 GMC 1/2 ton with a harness from Chevy Duty. I went to NAPA and got a new Delco alternator. Put the harness in along wit a turn signal,also from CD,and everything worked. The next morning the battery was dead. Put the battery on the charger and put a continuity tester between the + & - cables. Went through the truck and when I disconnect the 10ga wire on the alternator the circuit is broken. This is the wire that goes up to the ammeter. A buddie, a Toyota mechanic, siad it sounds like the regulator is bad. So I take it back to NAPA and they put it on their tester and say it's charging so it's OK. I tell them about the problem I am having and they just look at me. No answer given. So I go to another NAPA and the guy does the same test with the same results. But he says, i hope isay this right, the alternator has been "energized" and after the engine is shut down it needs some type of load on one of the wires to discharge it. He says to do this with a lightbulb set-up.
Hey I'm just a woodworker and my truck is ready to go except for this. I took it out for a few little trips this weekend and then dissconnect the battery.
OK guys help me out so I can be "On the Road Again"!! | | |
#85812 07/08/2003 6:40 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You can cause the alternator to draw current if you hook up the continuity tester backward, so a better way to check is with an ammeter in the circuit or by connecting the negative up on the battery and shunting a bulb between the + terminal and the + battery cable. If you are still drawing current, then yep, the alternator is bad. I just experienced that very thing on my sister's Mazda. The alternator charged ok, but also discharged. A rebuilt one fixed the problem. It is more likely a leaky diode than the regulator, but it is definately bad. I have run delco alternators with nothing but a sense wire (one wire congfiguration) on 2 vehicles now with no trouble. The bulb just lets the alternator come on sooner, by leaking some current to the regulator. It is supposed to be switched with the ignition anyway, so it is out of the circuit when the engine is off. Mine starts charging at 900 rpm, and then keeps charging when idling, so I don't worry about it.
#85813 07/08/2003 12:12 PM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | You could move the 10 ga wire to the other side of the key switch. Thats the way I have mine it cuts the battery off when the key is out.
if it dosen't need fixed, break it
#85814 07/08/2003 11:36 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | That's not a very good idea, Kedso, alternators don't like to be open-circuited while they are being rotated. You may find that yours has a short life.
#85815 07/09/2003 1:27 AM | | Anonymous Unregistered | | Anonymous Unregistered | Not to mention that an alternator is capable of trying to force 30 - 60 amps (depending on the rating) through your switch . . . which will shorten the life of the switch as well! | | |
#85816 07/12/2003 12:38 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yes, that too. You could find your switch contacts welded together!
