Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (jmoore, frogfarmer, Jon G), 105 guests, and 4 robots.
Topics128,288
Posts1,058,574
Members48,492
Hey pros;
Swapping my 1950 216 out for a 1958 235 and Tom Langdon's engine swap guide says to switch out the front engine mounting bracket. I've looked at the one on my 216 and the one on my 235 and they look almost identical other than the 216 bracket has a hole on each lower outer edge (where it bends at about 45 degrees). My 216 didn't have anything attached to these at all.
Anyone have any idea whats different between the two motor mount plates? Both motors came from a 1-ton truck.
Thanks - Carmental
The only difference would be later 235 plates are not drilled for the 1950 front motor mount or mounts if it's a car.
My Blog
Thats great news Dave, that means I won't have to swap that piece out.
Just have to drill two holes I had to do it when I installed my 235 power glide engine in my 52.
Pete
There's some good info on this under "Engines" in the Tech Tip section of this board. Look for "Motor Mounts", there's a drawing with hole locations all measured out.
Good luck.
