11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,347 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Hey pros; Swapping my 1950 216 out for a 1958 235 and Tom Langdon's engine swap guide says to switch out the front engine mounting bracket. I've looked at the one on my 216 and the one on my 235 and they look almost identical other than the 216 bracket has a hole on each lower outer edge (where it bends at about 45 degrees). My 216 didn't have anything attached to these at all.
Anyone have any idea whats different between the two motor mount plates? Both motors came from a 1-ton truck.
Thanks - Carmental | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The only difference would be later 235 plates are not drilled for the 1950 front motor mount or mounts if it's a car.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Thats great news Dave, that means I won't have to swap that piece out. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Just have to drill two holes I had to do it when I installed my 235 power glide engine in my 52.
Pete | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | There's some good info on this under "Engines" in the Tech Tip section of this board. Look for "Motor Mounts", there's a drawing with hole locations all measured out.
Good luck. | | |
