4 members (Peggy M, Gray_Ghost, Wally / Montana, 2-Ton), 106 guests, and 2 robots.
Topics128,052
Posts1,055,717
#857752 06/09/2012 2:59 PM
Getting more rocker noise and would like to adjust my clearances. Truck is a 1949 COE and removing the valve cover requires jacking up the cab (long story so I wont get into it here) which makes a hot adjustment virtually impossible.
So my question is;; what do I set my valveclearances for on a cold 248 cu GMC engine?
I usually see guys say about 2 thousands more than the hot.
Give me ambiguity
or give me something else
Sounds like a logical number. Thank you
Most people do not stop to realize that the rocker is wider then the valve stem. This makes the rocker only wears at the contact point. If you simply insert a feeler gauge between the valve and rocker the feeler gauge will bridge the wear point and give you a false reading. Unless you know the rockers are not worn you should check for wear and reface each rocker if worn if you want quiet results.
My Blog
