2 members (Bill Hanlon, 1 invisible), 62 guests, and 1 robot.
Topics128,049
Posts1,055,679
#857855 06/10/2012 2:57 AM
ok guys
I have the option of converting to 12volts via changing alternator, 12 volt battery and some light bulbs/switching bulbs etc. or just get a 6volt alternator from Fifth Avenue Internet Garage and leave the original lights etc. Soooooo what should a guy do?
Owner of a long awaited 1951 Chevy 3100 Pickup
Do you have a working 6v generator?
Do you have enough accessories to need the extra amperage of an alternator? About the only vehicles to use the alternators originally were police cars, ambulances, and fire trucks, etc. There's absolutely nothing wrong with running a 6V generator as long as it's set up with a properly-adjusted regulator and clean, tight connections.
I do have a 6 volt generator. The issue i have is the lights are not every bright and its difficult to start once the engine is warmed up.
I don't have any accessories, no radios etc.
I was wanting to convert to 12volt mainly for the brighter lights and better starting. From what i read about the 6 volt alternators from Fifth Avenue Internet Garage is that their alternators keep charging at low RPM's therefore i should not have problems running brighter lights and shouldn't have trouble starting.
Alternator is $210, switching to 12volt they say is about $150 plus a battery.
You have other issues to deal with, even if you need (or want ) a 6v alternator. Check out this thread.
I agree with Tim. Even if you spend the extra cash on a 6V alternator, you won't solve the problem, and the only reason converting to 12 Volts makes a difference is that there's twice the voltage to push the current through loose, dirty connections. Spend a little time with a low-reading voltmeter finding the voltage drop points in the circuit instead of throwing money at the problem.
Thank you guys. Looks like i'll have a good weekend project for next weekend.
Noonie,
You also might want to change out your headlight bulbs.They get dimmer with time. Also, the new ones are Halogen. Wagner H6006.
Every six or ten years or so I go through/clean/tighten all the major connections on my '51. Works great, no complaints.
Kurt
