| | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | I bought a '53 cab to replace the one wrecked on the Blue Funk (a '51).
The '51 cab had its parking brake pedal on the left side of the cab near the wall. The '53 cab seemed to have its parking brake lever to the right of the transmission. The '53 has a hole in the transmission cover plate just to the right of the hole for the gearshift.
I looked through the Factory Assembly Manual and noted the two diffferent types.
My question is: What would be the best tact to take in order to get a modified parking brake system in place?
Thanks.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Dave, What kind of parking brake will you use in your truck? The foot-pedal actuated one, or the hand-lever actuated one? Most likely you'll be using the foot-pedal actuated parking brake? Is there a hand lever assembly on your transmission? If so, you can take it off. Is the foot-pedal set-up now in place? If so, just get a standard four-speed transmission cover? Reproduction fiberglass covers are available, but I'd place an ad in the Swap Meet to try to find an original metal cover. The hand-lever actuated parking brake was used on larger trucks (on some 1-ton and on 1.5 and 2 ton trucks) with the drive-shaft brake (propeller shaft brake). | | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | Thanks for your reply and the link, Tim.
I would like to use the foot pedal actuated parking brake, and I believe I'm going to have to, as there is no hand lever assembly on my transmission.
I believe I can use the '51 cab's transmission cover since it wasn't too banged up in the accident.
My area of concern is with installing the foot pedal system. This was a point of impact and the components took a beating.
It also seems that the '53 cab isn't set up to recieve a foot pedal sysytem. For example, there isn't a hole for (what I believe is called) the anchoring rod. Edit: Actually, it's called a "lock bar".
Any information and/or guidence is appreciated.
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | My 52 has a cover plate screwed down where the foot brake rod would go through the floor. You might want to check really closely to see if there is a cover plate. I'd be interested in the trans cover plate with the hand brake hole in it. Good luck, GMCPic [email protected]
Dance like no one is watching, Sing like no one is listening, Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420 1948 GMC FC253 1t Factory 80"x9' Flatbed Dually 1948 Chevy COE 2 Ton 8'x15' Flatbed 1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton Cab and Chassis 1942 Clarkator 6 MILL-44 Heavy Aircraft Tug 1942 Ford (9N) Moto Tug with 1/2 yard Loader 1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
| | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | Well, after doing some research on past forums, the manual, and parts catalogs, I believe I have a handle on the situation.
First, I should have named this thread "Light Duty AD Cabs vs the AD Big Bolts", since the year of the AD Cab is not the issue. As Tim pointed out, the bigger trucks used a hand lever assembly whereas the lighter trucks utilized a foot actuated assembly.
What really brought it all together was a thread that occurred about a week ago and Dads50 Photobucket Account, pic #124. The difference is a bracket that attaches to the firewall. As Dads50 pointed out, the bracket attaches to the firewall and the inner fender attaches to the bracket. The parking brake lock bar goes through the toe pan and the foot lever goes through the cab floor and attaches to a cross assembly.
I'll email you about the transmission cover,GMCPic.
Thanks for the interest. | | |
