| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 127 | Starting to get frustrated on this tuneup. I have a 54 chevy with a 235. it has holley 390, split headers, pertronix ignition. i have been trying to tune it correctly for awhile. I rejetted carb and changed power valve to what is recommended from clifford performance. My problem is while driving at higher rpms, when i let off the gas, i get lots of popping and backfire through the exhaust. that is my only problem. the throttle response is good, no hesitation or backfiring on acceleration. I have timed the engine from 0 degrees all the way up to 20 degrees advanced. When I retarded the timing, it got worse. When I advanced it, still backfire issue. the spark plugs look good, not to lean or too rich. Only backfires from high rpm deceleration. Also it is not initially when i let off the pedal, its almost when the rpms get back down to about 2k. Any help would be great, I am not sure what it could be. Thanks! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Try enriching the idle mixture screws a little. This can be caused by a lean idle mixture. Vacuum leaks can also cause it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Did your tune up include setting your valve lash?
It may not be your problem but its worth checking.
I had the popping on deceleration once. It ended up being a bent push rod throwing off my valves on one cylinder.
Good luck | | | | | Joined: Dec 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 127 | I have tried adjusting the mixture screws, more popping the leaner the mixture, I am 2 1/2 out now, if I go more out, there is a hesitation and still the backfire too.
I have not checked the valve lash, a little nervous about adjusting them. I dont want to screw anything up haha. | | | | | Joined: Aug 2011 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 45 | Make sure that there are no exhaust leaks, anywhere. On decel any fresh air that can be drawn into the exhaust system will ignite with hot unburned fuel and explode, causing popping and backfire.
The older I get, I only want to work on older rigs.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Have you checked your vacuum advance?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | Make sure that there are no exhaust leaks, anywhere. On decel any fresh air that can be drawn into the exhaust system will ignite with hot unburned fuel and explode, causing popping and backfire. I'm going to cast my vote with Joe. The leaks probably are in the first 18 inches of exhaust tract. Make a little smoke by feeding it a little oil/gas mix or diesel through the carb and watch for leaks near the manifold joints. Plug the exhaust outlet with it running while a helper watches and listens around the manifold. EXHAUST LEAK
Bob Taylor
| | | | | Joined: Dec 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 127 | how far should I advance my timing with the pertronix and 4 bbl carb? also, when I adjust my timing, I am seeing the timing mark about 4 different places when i twist my distributor... which mark should i go with for correct timing? thanks | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | there is only one timing mark, the little bb imbedded in the flywheel. Take the pertronix out, at least until you get this sorted out, but timing is the same regardless of what ignition system you use. You will have to adust timing whenever you switch from points to pertronix, and vice versa. I was extremely underwhelmed with pertronx myself, the old truck never ever failed me in 28 years until I UPGRADED the ignition, I could work on points for the rest of my life and still not have gone through as much misery as that one day. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My experience with that problem in various vehicles has been it is often caused by a lean condition.
