0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2001 Posts: 32 Member | | Member Joined: Jul 2001 Posts: 32 | I just pulled my transmission out of my truck. Im putting in my t-5 transmission from an s-10 this week. What i would like to know is my truck is a long bed. So what should i do about the drive shaft. Right now it has two shafts one short one off the transmission. and the long one after that. What is the best possible choice. For a drive shaft that i could use without having to take it to a driveshaft shop. mike | | | | | Joined: Jul 2000 Posts: 23 Member | | Member Joined: Jul 2000 Posts: 23 | Only costs about $40 to have a driveshaft shortened, you will probably have to change ends at the rear, or use special u-joint from napa for different sizes. I found oue just the right size from a passenger car to replace my 2 piece one.
57 3/4 ton rat 66 C-10 panel 350 200R4 3.07 axle 68 C-20 dump runner, 250 4spd, 4.11 82 Camaro, 305, THM-200-R4 84 Monte Carlo, 350, TH350 EVERETT, WA
| | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | | | |
#8574 12/06/2001 11:14 PM | Joined: Jul 2001 Posts: 32 Member | | Member Joined: Jul 2001 Posts: 32 | Thanks for the replys. What kind of passenger car was that that you replaced the two piece driveshaft with. Thanks for the information. Mike | | |
#8575 12/07/2001 11:12 AM | Joined: Jul 2000 Posts: 23 Member | | Member Joined: Jul 2000 Posts: 23 | I put a 200R4 in to replace my 3spd. Had been having problems with center bearing (because I had put in mewer bell housing with rear tranny mount, and the mount was bad). Here in WA any tranny is $50 from a pick and pull next door, pulled pan on 1st 200r4 clean, would not shift to OD, returned it for another, had a vibation I did not like, got a 3rd one, teriffic. 200R4 is longer, did not want to pay driveline shop, splines were different. Pulled a couple of shafts, one I used was from a 4door chevy, mid 80's. if was about 3 1/2" too long, so shoved v8 up to front mounts plus a little, running electric fan from citation, no problem. newer rear u-joints are bigger, but napa sells u-joint with old and new diameters, pretty common. I have a panel, after being under about 100 gm cars, I'd say there are probably 30 different driveshaft lengths on 80's cars! Here is a link that everyone should have that tells you everything you should want to know about GM automatics: http://my.en.com/~thall/olds/oftrn.htm
#8576 12/13/2001 12:18 AM | Joined: Jul 2001 Posts: 32 Member | | Member Joined: Jul 2001 Posts: 32 | Its me again. I am now wondering what should i do about the clutch setup. Can i run it stock or will i have to change the stock setup to what it says in the article int the tech tips page. Thanks, Mike | | |
