7 members (Otto Skorzeny, Hotrod Lincoln, Slick Willy, 1955 1 Series, GrandpasJimmy, BarryP, 1 invisible),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,925 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | Has anyone ever seen a short bed on a longer truck? Wondering what it would look like to use a short bed on a truck like a 1-Ton with 137" wheelbase. You could then use the extra 21" between the cab and bed for a toolbox or even an extended cab.
Anyone have any pics of something like this? | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I've seen some and can't really say any of them looked good in my opinion. All that matters is if it looks good to you though. Are you talking flat/platform bed or pickup bed? | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Most look bad because of the space below the toolbox. I think if you used long bed steps, and then used a tool box that was made to fill the space between the bed and cab, it would look good. Using a regular tool box that is notched for the bed won't look right, IMO. Dare to be different!
| | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | | | | | | Joined: Nov 2000 Posts: 1,971 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,971 | *
Professional Novice
| | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | interesting... yea that's exactly the look i was talking about. suburban frame but same idea...
Maybe it"s the angle but i think he could have rounded the top back of the cab more... even so, i don't think i like it... hmm. thought i would but it just doesn't seem to work,,, | | |
