2 members (Chip O, 1 invisible),
89
Mod | | | Forums66 Topics128,188 Posts1,057,217 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 20 New Guy | | New Guy Joined: Jan 2006 Posts: 20 | Hi all,
I am trying to remove the front fender on my 58 Apache pickup (1/2 ton), and I believe I have removed all the bolts I can find on both the inner wheelwell and under the hood. I must be missing something . . . I ordered an assembly manual for the truck, but it won't arrive for 2 more weeks.
Can anyone give me any tips or email me a scanned page of that part of the assembly manual?
The back part of the fender seems to be free, but I can't seem to get the headlight part separated from the grill . . .
Any help would be GREATLY appreciated. Many thanks to you all!
-Joe | | | | | Joined: Jan 2006 Posts: 20 New Guy | | New Guy Joined: Jan 2006 Posts: 20 | It's the passenger side fender . . . but I'll also be removing the drivers fender once I get this one off.
Thanks! | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | You have to stick your head way up inside the fender well and there are a couple hiding there... Won't tell you where cause what's the fun in that?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | start with removing the grill, hood latch panel at the top, and the rest of the bits that tie the fenders together at the front
Bill | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | There's 5 or 6 bolts around the headlight bucket. Really hard to get unless you remove the headlight bucket, grille, etc.
58 gmc 100 with 350 sbc
| | | | | Joined: Jan 2006 Posts: 20 New Guy | | New Guy Joined: Jan 2006 Posts: 20 | Thanks for the replies!
I have removed the grill and hood latch panel.
Those 5-6 bolts around the headlight bucket, are those the clutch-head bolts around the headlights underneath the headlight trim piece?
Thanks again for the help! I'm hoping to get this fender off today!
-Joe
Joe 1958 Chevy Pickup 1990 Ford F250 1997 Ford Ranger 2003 Harley Davidson
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the clutch heads are to remove the headlight buckets, if you are going to eventually do that anyway, but that's not necessary to disassemble the clip ... to get the fenders apart you need to take out the bolts that go into the end of the bar underneath the latch panel, there's 2 on each end, up high as CASO said - there's also some on each end down by the splash pan - the complete face needs to come apart before the fenders come off, just keep poking around up front and you'll find all the fasteners
Bill | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | The front end on my 58 all the bolts were so rusty that most of mine just broke off. If you don't mine removing the radiator its easier to just pull the whole front clip in one piece and then separate the fenders from the inner panels.Larry
| | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | Feel around in there. They are difficult to see and may be covered with undercoating. I have removed a fender without completely removing the grill or the hood latch panel. The bolts you are looking for are on the flange between the fender and the piece that goes behind the grill. It helps to remove the headlight bucket though as it gives you a little better access. | | |
