2 members (Rusty Rod, porsche),
64
Mod | | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | I have a LWB 55 series ll pick up with a 235ci I6. In my father's garage we have a 327 out of a 67 pick up. I was wondering if this would fit in my 55 and if anybody knows whether it will bolt up to the original four speed in my 55? The four speed is original with the ultra low first gear. It was rebuilt last year and it would be a shame to have to exchange it for the 67 automatic. Would my I6 bellhaousing,flywheel and 11"clutch work on the 327? Thanks! | | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | Transmission will work if a 55-57 v-8 truck bellhousing is used. Flywheel will not work but clutch/pressure plate will.
Bob Taylor
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy sepp, I would add that you will have to purchase a front engine mount kit from one of the vendors, hope that helps. | | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | My 1964 parts book indicates the bellhousing is the same 55-59 pickup through 1 1/2 ton.cast 3776887. 55-57 passenger also had mounts on the bell housing so they could be adapted easily.
Bob Taylor
| | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | The inline 6, 235, bellhousing and the V8 bell housing are different for that erra. The 64 inline 6 did use the same bell housing as the V8.Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | There's a good tech tip about the bellhousings here . As others have stated your 235 bell will not fit a V8 but any 63 or later 194/230/250/292 bell will bolt-up to the V8. The truck bells described in the tech tip will mount to your crossmember same as the 235. The front/side engine mounts are different, but as others stated there are crossmembers/mount kits for that.
Professional Novice
