4 members (Rick Brown, Bill Hanlon, 2-Ton, 5 Window 9434), 198 guests, and 1 robot.
Topics128,108
Posts1,056,238
Members48,437
#856964 06/06/2012 5:20 AM
I've never read any discussion about this topic so thought I'd bring it up. I'm always on the lookout for old carbs at swap meets and have picked up a couple of Rochesters with auto chokes. I have a 1950 216 engine with a model B Rochester with manual choke. I don't have model numbers for the carbs I have with auto chokes, but could someone tell me if they would work on my engine? Don't know if it would be possible to run the heat tube someplace on the manifold but it doesn't seem like it would be that difficult a job. Has anyone done this before with good results? I'd like to rebuild one of them and try putting it on my engine if it would work.
Thanks.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Post some photos and info on the carbs and im sure we can help here on the forums.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
It looks like Rochester automatic choke carburetors were made for 216/235 engines back to 1932?
http://chevy.oldcarmanualproject.com/carb/Rochester/index.htm
They were called BC carburetors (C = Choke)
I have the standard Rochester BC carburetor on a 235 Hydra-Matic transmission on a 1954 235 truck engine. Up until that year, the BC carburetors were used only on car engines.
One thing to consider is the base mounting-hole-to-hole distance, 2 5/16" vs 2 9/16".
