1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | I've never read any discussion about this topic so thought I'd bring it up. I'm always on the lookout for old carbs at swap meets and have picked up a couple of Rochesters with auto chokes. I have a 1950 216 engine with a model B Rochester with manual choke. I don't have model numbers for the carbs I have with auto chokes, but could someone tell me if they would work on my engine? Don't know if it would be possible to run the heat tube someplace on the manifold but it doesn't seem like it would be that difficult a job. Has anyone done this before with good results? I'd like to rebuild one of them and try putting it on my engine if it would work.
Thanks.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Post some photos and info on the carbs and im sure we can help here on the forums. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It looks like Rochester automatic choke carburetors were made for 216/235 engines back to 1932? http://chevy.oldcarmanualproject.com/carb/Rochester/index.htmThey were called BC carburetors (C = Choke) I have the standard Rochester BC carburetor on a 235 Hydra-Matic transmission on a 1954 235 truck engine. Up until that year, the BC carburetors were used only on car engines. One thing to consider is the base mounting-hole-to-hole distance, 2 5/16" vs 2 9/16". | | |
