1 members (Ponchogl), 130 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#85641 04/25/2004 6:20 PM
I have a couple fuel level gauges from 47-53 trucks and while installing one I found that the sender wire post is connected to ground (like the gauge housing). Is this correct? I would think it would never change it's reading from the fuel sender. I tested another and it didn't do this. I figured the first one was bad until I read that the GMC might be different?
'53 Chevy truck 1/2 ton
#85642 04/26/2004 3:05 AM
The post shouldn't be connected to ground. Replace it with one that shows a change in resistance when the float arm is moved through it's travel and you should be set.
Joe
