2 members (Ponchogl, Shardean),
85
Mod | | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | I noticed that my gas pedal would accelerate on it's own when I hit a big bump so I checked that my motor mounts were tight. The driver side front mount was not. The top nut was stripped and when I tried another one I discovered that the bolt part of the mount was also stripped. I have a 235 in a 1959 1/2 ton Apache. I have been checking all of my catalogs and I can't find a replacement anywhere. I was thinking of fabricating one out of grade 8 all-thread if I cannot locate a replacement. Does anyone know of a source for the motor mounts or if my idea of making my own would work. Thanks for any suggestions. Gene
Gene 1959 Apache
| | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | I think I got it fixed. I put a new lock nut on it and then chained the engine down with a turnbuckle just to be safe. I bought the stuff I need to fabricate a new one if I ever get around to fixing it right. Thanks anyway, Gene
Gene 1959 Apache
