7 members (69 coupe, Gdads51, Phak1, jmoore, TUTS 59, 54farmtruck, 1955 1 Series),
91
Mod | | | Forums66 Topics128,188 Posts1,057,329 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 48 | Got a new voltage regulator for a '48 GMC fc303 1.5 ton that still has the original 6 volt system.
The instructions in the box said to polarize by touching the jumper wire to ARM and BAT but not to touch the FLD.
Problem is, We have a reproduction owners manual that says (page 97) to remove wire from FLD at the generator and touch FLD terminator on generator and BAT termonal on egulator with a jumper wire.
Which way is right on a Positive ground system??
| | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | It depends on whether you've got an "A" circuit or a "B" circuit generator. Most Delco generators have an A circuit which means the regulator provides a ground for the field current. On the B circuit, which was used on Ford products mostly, the field coils are grounded inside the generator, and the regulator provides a voltage to excite the fields, not a ground.
The simplest way to tell the difference is to look inside the generator. If a small-diameter wire taps off of the Armature terminal and goes to the Field coils, you've got an A circuit. If one end of the Field coil winding goes to ground, it's a B circuit.
Polarize an A circuit generator by flashing the Battery to Armature terminal at the regulator with a jumper. Nothing needs to be disconnected. Polarize a B circuit generator by removing the Field wire at the regulator, and touching it to the Battery terminal. Jerry
