8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible), 58 guests, and 1 robot.
Topics128,049
Posts1,055,699
#85631 05/29/2004 3:19 AM
Junior Member
Junior Member
Trying to get spark. Is there an easy way I can test my coil?
#85632 05/29/2004 3:24 AM
Red dot, center of chest ...
Take the coil wire out of the distributor cap and put it somewhere close to metal on the engine. Then disconnect the wire that connects to the points. Turn the ignition on, and touch metal on the engine with the wire that went to the points and then remove it. This simulates the opening and closing of the points. Each time you do this, you should see a good, blue spark jumping from the coil wire to the engine metal.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
#85633 05/29/2004 4:48 AM
An easier way: put one hand on the coil wire and one on the fender and have someone crank the engine. grin
#85634 05/29/2004 12:12 PM
Cletis must have been one of those bad kids in school!
You should be able to get about a good 1/4" blue arc out of it. If you get a lot less, it is not good enough.
1951 1 Ton Completed
